gavin m
I would double check that the brackets will fit the 32 axle first but for me personally they look a touch overkill and also not a very pretty thing to have clamped around the axle.
You don't actually have to attach anything to the axle, you can mount the one end to the tie rod with a simple tie rod clamp and the other can be mounted off the wishbone. I couldn't do this with my setup as it a spring behind axle front end so ended up making a bracket that comes off the front crossmember. It's not the ideal place for it but it it is more hidden there and has worked fine for two years now.
