vern hodgson
Left garage on a four mile cruise, two miles in, engine cuts out and restarts happened second time, restarted, third time no go, no lites, no horn but turns over. Where to look, terminal box, switch?
If no fuse as Bob suggested, then jump the two terminals together in the firewall junction box. That will bypass the Amp Meter. Repro meters are failure prone, and fits your description of no lights, no horn, no ignition, but turns over.
I carry an old distributor primary cable end with the armor stripped off and a spring clip attached.
A jumper lead as GR suggests is a good thing to carry around.
I have one also
Back in the day the cops would pinch you for having one of those
Just so I undestand. Do you mean you are putting a jumper on both the driver and passenger side of the dogbones?
So… dropped t box cover, no juice on either terminal, inspected wires all seem ok, laid a wrench across t box studs and hit the horn button. She sounded off like a new bride on her honeymoon. Replaced ammeter. Now to find an original.
So a big THANKS to every one. What a feeling to conquer the dreaded electrical monster
