Hello All, and Happy Memorial Day.....
I am in the process of prepping my late father's 31" coupe to find it new home.
It's been in the family for decades and was an older ground up restoration.
The horn is DEAD, and I could use some help/tips on troubleshooting. I am a car guy but not specifically educated on Model A's even though they are pretty simple.
A few thoughts:
When I push the horn button, the ammeter gauge ticks to the left whether or not the key is on? Shorted button?
Dad soldered the wires from the horn to the harness, so I may have to cut to pull horn and bench test. I assume that I add 6V to the 2 terminals underneath and see if it works?
What is the best way to use external 6V to try horn while in car?
I had the rear cover off of the horn and went to move the armature shaft and accidently touched the mount frame and got a spark with key off? I would think I should not have any voltage there with key off?
I have not been able to figure out how to get to the horn button switch on the steering wheel? I think it has a C clip at the bottom of the steering column that when removed allows the rod to be pulled out. Thus far I have not seen or felt that??
All I know.....
Any thoughts or advice on troubleshooting appreciated.....
Thanks, Scott in Colorado
A few thoughts:
All I know.....
