Dazed and confused
34fordy
When installing a 37 engine with 36 heads and block off plates, can the 34 water outlet/mount be used? Different suppliers sell spacers/offsets etc. and I cannot seem to figure out what the differences are. I have a 37 engine with block off plates and what I think are 35/36 outlet/mounts. Determining the correct parts to get the front of the 37 engine at the correct height and orientation has me more confused than usual.
What vehicle? 33-34 mount spacing is narrower than 35 and subsequent models....if you're fitting this engine into a 34, you'll ideally want 33-34 mounts. 35 or later use 35 or 36 mounts; they are different each year to line up with the radiator
Thanx Brian. 37 with block off plates going into a 34. I think I muddled up the question too much. I should have just asked----Will the 33/34 inlet/mounts bolt up to the 37 engine with block off plates?
