I realize that to be able to adjust the lifters is superior to the old way, but I am curious just how it was done with the grinding method. I'm sure there's several here that have done it that way and I'd love to hear how it was done.
Darol
Ok hears the true old skool tech for non adjustable lifters.
there is a tool that you insert into the valve pocket . you set the cam on the heal and slid the tool in until it sets directly on the cam heal. there is a sliding 45 degree ring that you set right on to the newly ground valve seat. You then lock it in place with the t screw so it will not move . You then have another tool that has a 45 degree seat you insert the first tool into .On this receiver tool at the bottom is a micrometer that measures the total distance from the valve seat to the cam heal. then you subtract the valve lash clearance you wish and that is the length of the finished valve .If your valve is to long then you will know just how much to remove from the valve stem. there is a micrometer on the but grinding end of the proper type valve machine that you can set to cut just what needs to be removed .I'll take photos of the tools tomorrow and post them here. when a cam has been reground the base circle is reduced and some times you will need longer stems on the valve . 1.5 Chevy valves will do the job as they are 100 thousandths longer in the stem. however depending on how much was ground off the cam and valve seat will determine how long they need to be cut down..I hope this helps everyone understand how its done.. Look for photos tomorrow ....John
Looking forward to the pics John, not seen the proper two measuring tools.
Martin.
