51f1truck
My 52 Ford F-1 with the 239 ci V8 flathead ... new radiator, pumps, engine cooked cleaned, new 180 deg F thermostats. I have a mechanical temp gauge that I have swapped to both heads. The mech temp gauge runs very steady at 180 degrees so I feel good about how the flathead is running.
My problem is my dash gauge reads very near "H" while driving. Now as we all know, when the ignition is off, the temp gauge goes to "H". When I first start it, the gauge works like expected and drops to Cold and then starts to move up as I drive. The problem is that when I am running at 180 deg normal operating temp, the gauge reads very near "H".
I tried wiring it with and without the double terminal excessive heat switch, no difference. I purchased a replacement single terminal temp sender, no difference. I installed a second dash temp gauge that I have, same readings near "H" while driving.
I am stumped. I don't understand why the dash temp gauge read so close to "H" when driving at normal temps. I don't want to install aftermarket gauges in the cab as I think this will take away some of the "stock" look I have been working on.
Any ideas on what else to check... or is this typical ?
Fred
Fred
