If your 55 originally came with a automatic there should be a extra socket floating around under the dash,if its not there just find a socket that will fit the hole and tap into a dash light wire and you are done. I accidently knocked mine out and since its not grounded the bulb will not light up so you wont see a light under the dash when the lights are on.
