Not sure, but maybe others can confirm:
would
this bulb work?
"81 LED Bulb 6 Volt Positive Chassis or Negative Chassis Miniature bulb. The maxium bulb length is 1.24 inches and the maxium diameter is is .75 inches. This will fit the small size of a #81 light bulb. BA15S single contact. G6 single contact bayonet LED. C-6, C-2R filament design compatible, single filament Uses only 1 Watt at 6 volts. Uses very low power. The profile is very small to match the profile of the #63 bulb. The light output is up to 90 Lumens the #63 bulb has a rated output of 3 candle power CP, the LED is up to 6 candle power so about twice as bright as stock light bulb. This bulb is available in White 6000K, Warm White 3000K, Red 625 nm, Green 526 nm, Blue 464 nm & Yellow 594 nm"
