I have searched and searched and found varying information. 63 f100. Dana 44 rear. Swapped gears. Original shims behind rear/inner pinion bearing race and on pinion shaft.
Specs I've seen are 160-200 ft/lbs for nut torque and in/lb for preload ranging from 15 for used bearings, or 13-30 for new bearings.
With that being said I'm hitting 20 in/lbs before getting to 160 ft/lbs. Likely due to the shaft shims being worn. If I'm correct adding shims, on the pinion shaft seat, reduces preload as it moves the pinion/rear pinion bearing away from the race.
Sent from my Pixel 3 XL using Tapatalk
