barnfind08
Finally got around to starting up my new 36LB engine. Runs great now I want to wire the generator. Ignition turned on the ammeter goes negative(likes it is supposed to do). There is 2 wires coming out of the 3 brush gen. Where do these 2 wires go? The wire from under the dash that is at the fuse block goes to the "BAT"(B) on the cutout. I am assuming ones is ground? and goes under a screw holding the cutout and the other goes to the other side(opposite of the"B". How do you tell which is which? Do not want to smoke my generator. Thanks for the help Fred
