rons49 Senior Member Jul 1, 2014 #1 Will the cutout function with the battery connected as a negative ground?
Ron in Quincy Well-known member Jul 1, 2014 #3 When I convert a cutout to a diode I purchase positive ground, 30 amp, diodes and wire the battery positive ground. I believe with a regular cutout it should function OK ? Ron
Willie Krash Well-known member Jul 1, 2014 #4 You could modify a diode type by reversing the leads as opposing to by another.
rons49 Senior Member Jul 2, 2014 #5 Thanks, I was under the impression that the original would work either way. But, I was not sure about the diode. Ron
