Cut out on '39 generators?
CGW
Hello.
I am wondering if a '39 generator would have a cut-out on it?
How many different types of generators were issued in '39 for passenger cars?
When was the last year for cut-outs on generators?
Thank you for your time and replies, Ford Barn.
-CGW
On the wiring diagrams the 39 std shows a cut-out and a 39 dlx shows a voltage regulator, but I have no idea on the production dates. Kube would be a good source for that information.
Thank you JSeery.
From your reply I can assume there were different generator set-ups for standard and deluxe. This is helpful.
I hope to hear from Kube on this matter too.
-CGW
Here are the diagrams if that is of interest to you. Different generators, 2 brush vs 3 brush.
The generators are totally different for a deluxe and standard. Two brushes versus three. Voltage regulator versus cutout. You may want to find someone with a copy of the '38-'39 Book which was done by Gary Mallast for the V8 Club of America or go on the EFV8 Club website and purchase one. Anything you need to know is in this book.
1939 was the last year for a cutout. In the initial part of the production run (1939 models) the Standard did indeed get a cutout while the Deluxe got a regulator. Around February, 1939, all models, Standard and Deluxe were supposed to have a regulator installed. How quickly that actually took effect is anyone's guess. Probably within a few weeks...
Note that the generator was specific to a regulator OR a cutout. the two could not be interchanged.
There is speculation that throughout the entire production ruin, the Standard, when ordered with a radio, got the voltage regulator. I can't say how true that is.
Mike, "Starting February 1938 two-brush generators with voltage regulators were specified for all radio equipped cars."
This quote from the '38-'39 Ford Book, page 7-25, which is also referenced in chapter IV, and in Running Changes in chapter VIII.
Thank you for your input.
I appreciate you all taking your time to educate me on this subject.
Thank you Ford Barn.
-CGW
39 standard used a 3 brush gen with a cut out , fan mounted on gen, 39 deluxe used a 2 brush gen with a voltage regulator, fan mounted on front of crankshaft
Not always. Read through the previous posts.
I have a 39 Standard that originally came with a 3 brush generator and cutout. The output of this generator is only rated at 15 amps at 6 volts. When driving at night with headlights and a heater when the generator is adjusted for maximum output it would "sling solder" out of the commutator and still not keep up with demand. I ended up installing a 2 brush with regulator for normal use. I believe the 2 brush generator is rated for 30 amps.
Being in my 50s, I'm a little of both. One foot in, and one foot out. Hopefully.
