Cut Off Switch?
Baypac
This item is mounted on my truck firewall between the battery and the starter. On the inside there is a slotted fitting.
I am wondering if it is a battery cut-off.
Thanks,
Thanks,
It looks like it would be a cut-off switch - look inside the car on the firewall to see if there is a switch. Test using your headlights or dash light.
It is hard to tell but the red battery cable looks like it might be a 12 volt cable. If your car is 6 volt it should be replaced with a 6 volt cable.
