cut off switch
I mounted the lever type on the top frame rail right next to the battery. The location is such that I cut a 1/2 circle notch in the floorboard at the edge of the battery access hole and the battery cover plate covers it. Flip up carpet & plate to operate.
As stated by Bruce and others , try to get the "good switch" and mount inside the car.
Check out Cole Hersee ( Little fuse co.) on line for a variety of options, short , long shaft, etc. to fit floor board and other config's.
Very similar to what we did in the truck Ray, but we used the other type of switch. Easy to reach, and out of view under the mat. It's mounted in the existing hole it the frame cross member just in front of the seat riser with access through a small hole (3") drilled in the floorboard
I've been off FB for a while but here's my take. Mount the switch in the seat riser if your A has one and switch the ground. Anything moving around under the seat will not create sparks when up against the connections. I've seen holes drilled in freshly restored firewalls and wires cobbed together. Keep it simple and add an extra ground cable to the transmission or flywheel housing.
On my tudor I cut off a switch bracket that previously was used to mount the cut off switch to the starter bolt.Then I drilled a hole in the middle floor board and routed out the floor board so the plate would fit flush with the floor and used an original floor board screw to secure the plate/switch assembly.I reused two switch cables the vendors sell to wire the switch to battery positive(ground side),and from the other side of the disconnect switch to the center cross member.I grounded it to the cross member using an existing unused factory hole above the brake light switch.Not sure if something like this would work on a coupe. Dennis
