Custom building vintage style wiring
Ranchero50
Hey guys, looking for sources of vintage cloth covered wiring and especially the large rubber heat shrink covers for the eye terminals for my speedster.
I'm going to use a '49ish dash mounted ignition switch and need to do some custom wiring for that and the same era gauge lamps.
Photo so you know what I'm starting with. :)
Thanks in advance.
Jamie
E-bay has been my source for the proper cloth wire sold by the foot also the cloth sheathing with the tar coating also sold by the foot. Good luck with the speedster I’m just getting started on mine!
cloth loom with modern wiring,shrink connectors ..
Thanks for the ideas. I'm actually trying to find the heavy walled insulation that goes around the wire terminal. I assume that it's some type of heat shrink but it has a 1/8" thick wall. Probably should have calle Jeff at Bratton's today but I've been crazy busy at work.
Maybe you're thinking of asphalt loom?
They use it on Model A and AA commercial headlight conduits (instead of stainless flex loom like with the cars).
Comes in all sizes though...
Harbor Freight has a heavy wall heat shrink with an internal glue that melts and seals the joint. Marine heat shrink tubing. I use it on my airplane and Model A connections.
https://www.harborfreight.com/search?q=marine heat shrink tubing
It has 42 pieces and 6 different sizes in the box.
I don't think that stuff is thick enough. American autowire has it as part of this ignition switch kit.
https://www.americanautowire.com/shop/ford-ignition-switch-and-parts-includes-switch
OK, that's what I'm after. Rubber sleeve makes me think it's just repurposed tubing...
Ironic that I can't find the pics that you posted on their site. PITA but thanks for the info.
I use to make my own wiring harnesses . Now that color coded wiring harnesses are offered at a very reasonable price by some of the vendors , I use them . I always used the available headlamp wiring harnesses because I would rather pay the price than make the harness myself .
I custom made my harness,used weatherpack connectors in the headlight harness to make removal a snap..heat shrink connectors in wet areas,fuse protected relay operated circuits to reduce switch loads..LED lighting leaves a lot of ampacity, even at night..
I do similar on the modern stuff. This I want to look vintage, '50's at the latest.
Thanks,
Jamie
