I can't figure out what is causing this, so I'll ask for ideas. I have a 35 with the red fluid filled temp gage. It's probably original because the fluid has been red since 1975 or longer. The car has gone through being re-restored in the last few years. It was converted to 12V neg gnd. The fluid was to the top of the glass when I unboxed it and finally got the fluid back down into the bulb by hanging it up for several months and tapping on it occasionally. After installation, the fluid was just barely visable at the bottom of the glass at room temperature. I am assuming this is correct. But we all know what 'assume' means. I have started the car only a few times, but have not run it long enough to get the temperature up at all. Here is the issue--When the engine is cranked over, not running yet, the red fluid goes all the way to the top of the glass. When you stop cranking, the fluid drops back down to the bottom of the glass. What could be causing this? My theory is a poor ground during cranking and somehow its using the temp cap tube as a path to ground getting it warm real quick and making the fluid level rise. I used teflon tape on the bulb, so it's not a solid ground to the block. I was thinking about running some extra grounds to the block, trans, frame, etc. Any thoughts on this?
