I agree with Flamingo.
A crack is quite possible - Model A's do have some history of the block cracking between the exhaust valve seat and the cylinder bore on cylinders 2 & 3 .
(My own '28 has done this on # 2, and I am keeping my fingers crossed that K-Seal stop-leak will keep it stopped until I can get it overhauled.)
However, if you're working on something that's been sitting for a long, long time, would suggest leaving the oil-pan plug out, placing a clean container underneath, and filling the cooling system with clean water, and letting things sit for a couple days, and see if any water has collected in the container underneath...
If not, then you can probably put the plug in and re-fill with oil. Might want to check again after a week or 50 miles / 5 hours time on the engine.
