Gold Digger
Does anyone know of some kind of test strips or something to check for alcohol in gas that's supposed to be alcohol free. I've suspected some of the gas I've been buying is not what it's claimed to be.
You don't need to buy a kit. Use an old glass measuring cup. Put equal amounts of water & gas and mark the water level, then mix thoroughly. Let it settle and observe how much water is now below the gas - it will be obvious. Since the water will mix with the alcohol but not the gas, the increase in water level is the amount of alcohol. You can get the percentage of alcohol by dividing this increase by the amount of gas originally used.
I have one station that claims to sell nothing but alcohol free gas and I have no reason not to believe them. Also we have 3 other stations that say if you buy premium you get no ethanol that concerns me. Had a friend that tried premium from one of these stations and screwed up all the rubber hoses on his lawn mowing equipment.
I have yet to see a gas station where buying premium means no ethanol. The good gas was always a seperate pump labeled as such, and it usually sold for a dollar or so extra ove the cost of the cheapest 10% crap gas.
