crankshaft
Lawrie
Has anyone used the scat counter weighted crank,? if so how are they,are the same c/weighted crank the vendors sell?
Thanks Lawrie
The vendors sell the Burlington crank. LINK I've used three, one cross drilled after purchase. The Scat crank LINK has no oil slinger, you'll need to make up your own rear seal and thrust bearing. I've used one. You can buy the Scat crank cross drilled if you want. You can also custom order a crank to your spec, I imagine you could have them build one with a slinger and thrust.
Last time I heard scat A crank was something like $800. I know 2 people that have used them and they seemed to like them just fine.
