bob keenan
has anyone ever changed the crankshaft timing gear with engine still in the car? thanks for any help
It can be done, but it's a lot of work.
NOTE, he's asking about the CRANKSHAFT gear, not the CAMSHAFT gear, no special socket needed. Deep maybe.
If you throw any more than 100 degrees to the gear to remove it, you will be going to a builder to have the mains done. The front main bearing is DIRECTLY behind the gear and very susceptible to any amount of heat.The link posted didn't seem to help much to me, JMO.
The answer is yes, the crank can be changed while the engine sin the vehicle. The engine needs to be jacked pretty high which means the rear motor mount bolts need to be removed and the others loosened to allow the engine to tilt enough. Then it takes a 'real' puller, impact wrench and heat to get the gear off.
When installing the new gear, PLEASE do not hammer the gear back on. I've turned a couple pieces of pipe and welded a plate to the the ends to allow for using a bolt to 'push' the gear on. Heating the gear also helps with this.
I wouldn't put any kind of direct heat on anything close to the babbitt. It will take way more than 100 degrees to get that gear off and I have melted babbitt with a cigarette lighter. Use what you will but it only means more work for builders.100 degrees? The engine reaches way more than that in normal operating conditions.
