Looking for advice/tips on how to best install the timing gear on the crankshaft with the least difficulty or risk of damage to the crank (or gear, for that matter).
Any thoughts? e.g. heat the gear first, use antiseize, type of drift, etc.
Thanks in advance for sharing your expertise!
If the 1/2 moon key is out, or take it out, and lay emery paper on a very flat surface, and sand the two sides of the key so the key just slips through the gear with out binding in the gear, but has no excess, or other movement.
Use a brass hammer, or brass drift, and install the key, in the crank. Support, under the Key way, when installing.
Then heat the gear slowly, until it just starts to turn color, very little. Remember to have the timing mark UP. I set my gears on a 4" piece of thin wall pipe, so what ever it sits on, the heat won't get sucked out of the gear.
Have the crank standing on its rear flange, and drop the gear on.
It should seat with out forcing, but be prepared, just in case.
Herm.
