sconnors
I'm planning on installing a new crankshaft pulley on the Model A tomorrow. I've searched the threads here and have talked to some folks, and I understand I may have to jack the engine up. I have a new one piece pulley. Any hints, tips, tricks or advice from anyone who has done this would be greatly appreciated!
Thanks
Scott
Was able to get it done today. I had to loosen the rear motor mount bolts, remove the two front motor mount bolts, and remove the throttle assembly and then I was able to jack the engine high enough to get the pulley out.
I have to say I borrowed a Snap On cordless high impact wrench from a friend and what a job! After using a bar and a ratchet, the impact wrench did the trick in no time.
Thanks to everyone who weighed in here, you guys are all great! What a great resource to have when you need some help!!!
Thanks again
Scott
Thanks
Scott
Thanks again
Scott
