Hey Gang - for those of you who are looking for dimensional details . . .
I've just been going through the original Ford drawings for the 59AB and the 8BA engines (from the Ford archives). I've redrawn the critical dimensions in a parametric CAD program - such that I can validate them as accurate. What I mean by this is that when I draw the key centerlines/offsets/etc. and program in all the dimensions - the 'driving dimensions' will force the 'driven dimensions' to recalculate. This means that you can't really have a wrong dimension if all the lengths, angles, etc are correct.
What I've learned is as follows:
1) The drawings are correct - the geometry, angles and dimensions do work out (this is very good news).
Interesting facts (some are obvious):
a) The crank centerline does drive the deck height - even though the bore centerlines are offset from the crank. This is obviously true or you couldn't have the same length pistons/rods on both sides of the engine.
b) The bore angles are 45 degrees from vertical, but they are offset to the driver's side by .2651 inches. This results in the crank center-line versus bore center-lines to be offset by .1875" (in the bore center-lines)
c) The cam center-line is also offset to the driver's side - by .0242 inches.
d) The valve angles are the SAME between 59AB and 8BA (though different from earlier 32-41 engines. The passenger's side valve angle is 48.641 degrees and the driver's side is 51.385 degrees.
e) The overall length from the center of the cam to the top of the valve seat is the same side to side (about 7.0675), but the valve angle causes the driver's side valve to be higher (at the top side) by about .044. This was validated today when I was at my machine shop, the valve guy measured the height differences (side to side) at about .040. Those of us who've worked on these engines for years can attest to the tops of the valves being up higher on the driver's side. As a side note, it is rumored that some head manufacturer's (heard Edelbrock at one time) actually made different heads side-to-side for the 24 stud center water-neck designs (to account for valve angle, valve heights and chamber volumes).
Here is a bitmap image and a PDF of the CAD design - hard to see here, but you get the point:
View attachment FlatheadFordEngineCrossSection.PDF
Enjoy!
B&S
