Crankshaft dowels question....
Blownflatheaddeuce
Hey guys I have a quick qun :
i. Are the A engine/banger crankshaft - flywheel dowels the same as Flathead V8 ones? (Part # 6387)
I have sneaking suspicion that they are the same !!
Can anyone confirm ?
Thanx,
BFD
Crankshaft dowell B-6387 21/32" 32-48 Ford V/8
C & G Early Ford Parts 1-760-740-2400
don't know if they are the same as banger.
I put a Scat crank in an engine that I was building. I pressed some dowel pins out of an old used FH crank and then pressed them into the Scat. Worked for me, but I'm sure you can order new dowel pins from many of the old Ford parts suppliers.
