Anteek29
I'm running a stock 6V system in my '55 Fairlane. Out of curiosity I decided to measure the voltage present at my starter during cold cranking because the engine turns over real slow - even with a fairly new, full charged battery.
Under crank load the voltage at the starter motor was 3.5 volts.
Under crank load the voltage at the battery posts was 5.5 volts.
This tells me I'm losing 2 volts in the supply path...no wonder the engine barely turns over. Obviously, all the serial connections will be cleaned and tightened. Yes, the cables are the heavy gauge ones and I used an analog meter.
