Coop, I spent $$$s on it and it works great
, like my sons tell me that their car/trucks run better after they change the oil
The thing I liked about this is the ability to set two settings with vacuum readings taken, to control idle and then cruise. It helped a lot in oil leakage blow-out during boost versus the road draft hose I had dumping under the car. From Wagner web site:
Benefits:
• Fully tuneable to your engine combination
• Adjustable flow rate can be tailored to your engine’s setup, allows controlled incremental flow rate changes
• Adjustable vacuum transition level can be tuned to your engine’s unique vacuum profile
• Properly ventilates crankcase, resulting in cleaner oil and cleaner engine internals
• Reduces crankcase pressure, which is often the cause of oil leaks
• Eliminates in-car oil smell while driving
• Works well with air-oil separators
• Reduces emissions
• Reduces moisture and acidic vapors in your engine’s crankcase
• Vacuum gauge tuning method ensures PCV system is set properly for your combination
Tuning with Dual Flow Technology:
Eliminate the guesswork from your PCV system! Dual Flow PCV Technology gives you full control over your tuneup. The Dual Flow PCV Valve has independent idle and cruise circuits, each of which are adjustable.
The idle circuit’s flow rate can be tailored to your specific engine combination. The Dual Flow PCV instruction guide includes several starting points for idle flow rates based on engine size and idle vacuum levels.
A properly functioning PCV Valve will increase its flow rate under cruising conditions to accommodate additional blowby produced under higher load conditions. The vacuum level where the PCV Valve transitions from a low flow idle mode to an increased flow cruise mode has always been a source of guesswork, and is a critical component of your tuneup. Dual Flow PCV Technology allows the user to precisely set the idle to cruise transition point.
Question: I'm running a centrifugal blower I turbocharger I blow
through carburetor. Can I run a Dual Flow PCV Valve?
Answer: Yes. In this application the PCV line will be under positive
pressure under boost conditions.
We reverse flow test every Dual
Flow PCV Valve to 20 PSI as part of our QC process. Our experience
has shown that the Dual Flow's design has better backfire protection
than any stock valve tested due to its check ball design.
Glenn
