Posts 21-23 suggest this thread has taken a turn. I thought the goal was 500 mi per year, and possibly a budget build, based on 500 / yr. If you're going to start screwing around, mixing parts with a different crank, rods from another unknown source, probably not matched from the same engine, then you are starting down the path of a really nice build, but budget-be-damned. For one thing, now you have to add the balancing cost. I've done two engines this way in the last few years, one with a Merc crank, one with a Ford crank, and both were expensive because of the extra machine-shop costs, and extra new parts. I might add, in the case of the build with the Ford crank, I'm still able to source these cranks for free, but the end total still comes out $$$. I would re-evaluate the goal, and think carefully if the goal is 500 mi/yr. If the goal is to build a nice engine for your heirs to use and abuse, then budget be damned.
JMO
