Lawson Cox
My first car was a Model A and there was a guide for the crank that bolted to the front cross member with the spring U bolts. My 1939 PU has no guide other than the grille hole. Is that strong enough to guide the crank?
It may or may not be, especially if you fail to crank it properly. At least the 39 PU grill is stronger than the chrome 36 grill. I do not know why Henry stopped using the steel guide or guard for the crank on the front cross member.
