Crank shaft pulley
DANA BIZZELL
I think groove was machined in sleeve. Thinking of building clamp are drilling two holes and taping to install bolts for pulley puller. Does any one make pulley like this now days. any input.
Thanks
Dana
I've got the machined steel one piece pulley that Bill Stipe makes. Will never have to worry about that one coming apart.
Snyder's is making a correct to Ford spec pulley in one and two piece. We tested many before they started making them and could not find a two piece that was correct in physical dimensions. The meant they did not seal correctly on some and were too short on others which meant the nut didn't tighten the pulley enough, allowed movement and eventually they would fail.
