Crank ratchet nut thread
matchlessman
Would someone be able to tell me what the size and thread is for the ratchet bolt on the front of the crank? I'm about to pull the crank gear (I have a puller!) and I want to make a puller to put the new crank gear on hopefully without using heat.
Thanks,
Ken
Eastern Ontario
Would someone be able to tell me what the size and thread is for the ratchet bolt on the front of the crank? I'm about to pull the crank gear (I have a puller!) and I want to make a puller to put the new crank gear on hopefully without using heat. Thanks, Ken Eastern Ontario
Just measure the ratchet bolt you have and/or take it to a hardware store and match it up w/available nuts.
