bmwillia
Hey guys,
I have a fresh installed 59ab in my 33. I noticed a squeak/chirp coming from the front of the motor and after investigation I have found that the crank pulley is rubbing the oil pan lip.
The motor came with a double pulley on the front and I only needed a single so I took the crank pulley off to have the front pulley machined off.
Did I over tourque it when I reinstalled? Am I missing something?
You can see the shiny ring where it has rubbed in the picture below.
