smittykid
My 28 pickup has a tool box mounted under the radiator shell thus blocking the crank hole. I purchased one of those 1 3/8 offset wrenches to turn the engine for future timing(if needed) When I went to test fit the wrench on the 1 3/8" nut, I was shocked to see the nut was loose! I have not had any overheating problems. I was on the right side of the truck. The nut would tighten and I could turn the crank nut to the left, but when I pull it toward me, it loosens again. A mechanic told me this is not uncommon and just to tighten it the best I can. I still worries me. Have I got a major problem here or was he right?
