fredeuce
I am gradually re-assembling an 8BA . I have installed the crank and now looking at the other items to add to the engine.
I have picked up the front pulley and cleaned it up to prepare for some paint and to install.
After a trial fit I discover the pulley is not a snug fit on the keyway. It rotates considerably. On closer examination I discovered that the keyway in the pulley is worn considerably.
Having two other 8BAs in the workshop I retrieved the pulley from one of those engines. That was even worse .
Have a look at the pictures attached.
Is there a repair that can be performed on this worn keyway?
I don't think loading it up with loctite is the answer.
