Many years ago there were accessory front motor mount springs. The ones above the front crossmember were cone shaped and had rubber bumpers inside them .............. supposedly to absorb shock. Under the crossmember, where the motor mount stud cames through, rather than a third compression spring there was a thick rubber donut with a wide flat washer and castle nut .............. again to absorb shock. These springs and rubber pieces set the front of the engine just a bit too high for the crank wrench to line up with the crank ratchet. Take a flashlight to the front motor mount springs above the front crossmember. If they are anything but cylindrical in shape, this may likely be the problem.
