4 41 fatty Junior Member Feb 15, 2024 #1 to replace pulley and balancer on a 59AB, do I remove the crank bolt clockwise or counter?
glennpm Well-known member Feb 15, 2024 #4 You're welcome. The engine will probably turn over when you try to remove the bolt but not if you use an impact wrench. Glenn
V8COOPMAN Well-known member Feb 15, 2024 #5 glennpm said: You're welcome. The engine will probably turn over when you try to remove the bolt but not if you use an impact wrench. Glenn Click to expand... Although Glenn's suggestion should suffice, merely placing the trans in 3rd gear ought to offer more than enough resistance to get the bolt loose. Coop .
