57ChevyWagonMan
I am working on an 8BA motor. I have it all torn down and ready to go out for hot tank and magnaflux. Nothing outwardly wrong with the motor so far. Good .040 over 4 ring pistons, pin ends tight on the rods, bores are smooth with no ridges. Will need a couple of heli-coils in one cylinder deck and 3 in the other. My only concern is the crankshaft. It looks like it may only need a light polishing. A couple of marks on the No. 1-2 Rod journal that I can not catch my finger nail on. A little light rust on the main journal in line with the oil grove. The problem is all the bearings are marked .030. I can not seem to locate bearings of a greater undersize. I fear this crank may be too badly worn to use again unless I can get smaller bearings. Are smaller bearings available? Where can I get them? Were they ever available? Does anyone know where some NOS ones might be sourced?
I realy would like to brag that I got a complete engine on my first try and did not have to go through 2 or 3 to build a good one
Thanks so much for your help!
Mike
Mike
