Cragar Model B Engine
mhconley
New member
Kanab
UT
Price
8,000.00
SOLD
I am selling a Cragar Model B engine. This engine was built by my late father. It is on an engine stand and was running before he passed away in April. He removed the carburetors and put them back on the engine from which he borrowed them. The engine was running sometime after October 2019 and when he passed in April of this year. This is his written description of the engine:
  • Model B block with “poured mains” bored 4”
  • Full pressure to mains and rods with converted B pump to 40lbs
  • Oil pressure relief valve and oil filter
  • Counter balanced and drilled C crankshaft with 3” pulley and rear cork seal
  • Gusseted Pontiac rods w/inserts
  • .400 popup JE pistons w/aluminum pin retainers
  • Miller head with new gasket and early V8 water pump and adapter
  • New Manley BBC valves and springs
  • New Austin Healy 1¼ rockers with new rocker shaft and aluminum stands
  • Valve cover with custom spacer and valve cover gasket
  • New ⅜” pushrods and new IH lifters sized to Winfield specs
  • Winfield Super C cam with 280 degree duration and .410 lift (1¼ rockers) (timing 30/70 70/30), cam ground by Winfield in ‘53 with less than 20 miles
  • Bronze cam bushings
  • New aluminum timing gear and steel crank gear
  • Model B distributor with Winfield ground dist. cam and MSD coil and 6A ignition
  • Two carburetor intake manifold
  • Exhaust header
  • Custom side plate and port cover for block
  • Cut down flywheel and 9” Auburn clutch (no starter gear)
SOLD
One of the photos shows an index card with additional specifications. The engine is in Kanab, UT.
SOLD
Thanks,
Martin
SOLD
You can also find the engine for sale on Hemmings Motor News and eBay under his username - yelnoc34. My eBay username is vanhugh.
SOLD
