Cracked Roadster windscreen pillar
NZ28ModelA
Hi Guys,
When I tried to tighten up the windscreen pillar mount on my 28 Roadster Pickup, I discovered a crack running around the top of the pillar mount..
I have tried to attach pics but it fails..
I have hunted for advice but cant find anything out there..
Is it as simple as undoing the 4 screws and cutting the windscreen wiper cable to remove the pillars and windscreen as one assembly to get to the crack??
Has anyone else done this repair?? Can it be welded up in place?? I was wondering if there might be reinforcing under there?? Or a double skin?? or maybe wood??
Please excuse the lack of correct terminology.. Any advice will be welcomed and appreciated
Kindest regards
Steve
Pictures attached
Yes, a bit too much movement.. I had tried to tighten the screws before I noticed the crack opening.. Can I weld it??
Thanks Bob!! That shows me a lot!! I feel a lot more confident with what i am going to find.. I believe that can be welded no problem...
