Without going into the whole story, I recently inherited a '29 closed cab A pickup. It broke down on the 35 mile trip back to my house, and I hoped that it was a radiator problem, although I feared it might be something worse.
When I went to drain the oil, out came a quart of water, and I knew I was looking at a head gasket issue. Wet spark plugs confirmed that. Closer inspection of the head/block joint showed that it had been leaking and someone had "fixed" it with stop leak. To make matters worse, the engine builder had stacked TWO FelPro copper head gaskets - I could only suspect why and couldn't believe it had ran as well as it had previously. After what is easily the most difficult head removal I have ever done, I did not see an obvious gasket blowout that caused the leak, but I did confirm my hunch about the two head gaskets. The head was warped. It is also visibly cracked through the jackets between cylinders 2 and 3. Looking at the coolant passages in the block is giving me pause as well, although the cylinder bores look ok for wear.
The truck has a later motor, so I'm not worried about keeping it all original. I am in the market for a new head and wondering what aftermarket heads are out there that look stock beyond the Snyder or Brumfield. Would also appreciate any feedback on either of those heads, since they seem to be fairly popular. Looking for a good stud puller as well, if someone has a favorite. Thanks in advance!
