glenn in camino
I'm working on a Model A that the owner thinks has a cracked block. I don't have the equiptment to magnaflux it. Is there any other way to find the crack?
If he's using plain water look for rust stains, or does he think it's an internal crack?
And, why does he think it has a crack?
Water in the oil could be caused just as well by a blown head gasket. Any indication of that? Maybe rust has make a hole from the water jacket through to the crankcase. That's fatal for the block.
These Model A engines have a habit of cracking around the exhaust valves on No 2 or 3. I just sent a block to scrap because the crack had gone right across to the cylinder and was heading down the bore. I only had a drop or two of water in the oil.
I suggest you inspect closely around the exhaust valves but the only way to be really sure is get it tested.
They suspect a crack because there was water in the oil.
