As each person responds with their own variation & solution to repairing a block, I was recently put into this position when a good meaning friend
decided to help me out by moving a bare block that I had set on top of 2 milk cases so I could tap out the head stud holes and do some cleaning............
His helpfulness knocked the block over and it landed on the R R corner, breaking it in several places & several pieces. I was not happy with him to say the least! I've welded (or so I thought) for over 50 years, and 8 years ago I went back to a trade school to learn how to TIG and also properly Mig
weld (actually its Mag, but thats) and my teacher turned out to be a cool car guy. His explanation is more or less what I did here. I positioned the block in a way that gave me access to the majority of the cracked areas & pieces I had to replace. I formed a makeshift cover / shield that surrounded the top of cylinder # 4 but would still let the heat escape. I then placed a commercial style heat gun below cylinder #4 in the crankshaft area and turned it on high for about 2 hours - the front of the block became uncomfortable to touch and the back corner needing repairs was slightly smoking. When ready to "braze" the repair, I had my ex-friend hold a propane torch below the repair area on the outside of the block below the water passage to increase the amount of pre heat, and I then began to braze the patchwork back into place. Once all the pieces were assembled and their corners were just the slightest bit tacked, I took a 2" disc grinder and cleaned off any of the slag / flux from the braze. With the edges of each piece ground prior to brazing, I was able to flow a beautiful bead along each of the multiple cracks & pieces until it was completed. Once finished, I put everything away, cleaned up yet left the heat gun on high for about 1 hour, then turned it down to low for about 2 hours, then turned off the heat gun and set a small space heater in front of the repaired area and made a small tent out of some sheet metal and left that run till I went to bed. The repairs came out fantastic
and dressed down to a point that noo one will ever know. I just got the block back from another 'good' friend that decked the top of the block for me and it looks perfect. I can look down into the water jacket through the corner water cooling passage holes
that the head and gasket mate up with and the repairs look clean and solid and flowed well with great penetration at the joints. It was a learning experience, and I still have a spare block for sometime in the future.
