Crab Distibutor Vacuum brake pad gone
flatman
I want to glue a new leather pad on the vacuum brake plunger. What is the best glue. Cant remember what i used last time, but the leather fell off after only about 3000 miles. thanks for any help
I don't understand how it could fall off? I't's fully enclosed, and if you glue it down, then you can't turn it at a later date after it gets a deep groove.
I never glue mine. Do you have the proper pad? It should be at least 1/4 " thick, and between the rim on the piston and being captured in the chamber, there should be no problem, as "ford38V8" said.
I searched for a long time and was finally able to purchase a piece of 16 oz leather (the thickest available, 1/4" thick). I bought the proper size hole punch (I think it is 5/8") and make my own. It takes a lot of pressure to use the punch, and a hammer blow usually doesn't do it, so I use my press. I had to buy a 12" X 12" piece of leather so I have some left. If you need a new one let me know.
Thanks for the responses guys...I did the same, bought 1/4 inch heavy leather and then punched the proper size. I know the leather kinda just set in there and i just glued it in. Worked just fine til the knocking started the other day. Maybe my punch is a little small. I will try the next size up. If they are not supposed to be glued, then maybe my next size up will be a better fit. I will let you know how it turns out... thanks Jim
Well thanks guys. Punched a leather piece one size bigger and pressed it in. Tight fit this time. Learn something new every day. Now to just pull the distributor and remove the old pad. Jim
Oil won't hurt it. Chances are that is would get oily after a while anyway. I would'nt get carried away though. It has to have some braking action.
Also, the plunger bore and plunger should be VERY clean and have a light film of oil on them so that the plunger can move effortlessly when the slightest amount of vacuum is applied. Check to make sure there are no metal burrs or trash in the bore that can prevent free movement.
Thanks for all the replies....New button, cleaned and lightly oiled. Back to normal operation. Love the flathead...Jim
