Blownflatheaddeuce
Hey guys, I've disassembled a crab dist which was internally rust free, but find the advance weights are moving in their slots much at all - barely 1mm of movement there. The advance plate is stamped 11A-12181.
The slots themselves have a slightly raised "nub" in them which prevent the studs in the weights from moving any further than 1mm in their respective slots. If you look at the pic carefully you can see this. Is this correct/normal and if not how much movement should the weights have?
Also, how does that slotted advance plate come off so that the weights are exposed?
Thanx
BFD
Thanx
BFD
