From what i remember it is not a drilled hole, but an open area where several pieces of metal come together at the junction of the cowl, foot riser,firewall --not a drilled hole ---I only have pic of the upper routing (and dome light) --in the middle pic you can see the wire going down behind the upholstry.
Have you tried the search feature? I know someone in the past has posted pictures showing the wire coming from the light switch and through the small hole in the corner near where you might rest your left foot.
Not to hijack the discussion but I am looking for pictures of the cowl panel installation. I have ordered the correct slotted screws and cup washers from cartouche.
