Cowl Lights..
Tom Cavallaro
Is there a site or book specifically for installing cowl lights. I want to know what parts are needed and in what order they are to be installed. I was given the cowl lights and want to use them as turn signals. I could use the extra load to speed up the flasher...as I am using resistors for a load right now just to get the flasher working. Thanks in advance.
Tom
The service bulletins have several entrys about cowl lights(and some wiring routing in dome light heading too), and the Brattons catalouge has some pictures too
a couple things you will need. snyder lists a cowl lamp marking tool # A13300-X and the wood spacers that go between the panel and the inside brace # A 13318. The hole position is critical because the light arm has a foot that fits over the cowl band. I drilled the final hole a little smaller and dremelled it to fit. I also put an oring on the shaft just in case it leaked when it rained or I washed the car.
