Cowl lights- AV8 Roadster
PeteVS
A little out of place here, but I'm considering '32 cowl lights for my '29 open wheel roadster project. Any opinions? Thanks!
Pete,
It's your car, put I wouldn't do it. Less is more in my opinion. Especially on a roadster.
Tim
I just don't like other alternatives for turn signals / parking lights. Ant the stock A cowl lights don't look good either...
Pete, that’s why God gave us a left arm. Turn signals are built right in. It’s a hot rod, my man.
I'm with Tim Ayers, less is more...more or less :D
I don't think lights mounted on the cowl will look good. How about some small turn/parking lights on the front frame horns? Or maybe Guide style headlights with the turn/parking lights on top:
Sadly, at least half the drivers on the road today are clueless when it comes to hand signals. Some even interpret them as urging them to pass. I've seen some scary things happen to bicycle riders (that fraction that know which side of the road to ride on) using hand signals.
The smaller cowl lamps will likely look OK. The ones for 1929 are a bit large with the flat lens and there is really only one way to mount them unless you fabricate custom arms or something like that. Lucas used to make all sorts of fender tip lights and stuff like that but they are hard to come by here in the USA.
I have a beautiful set of A cowl lights that I'm using on the 27 T roadster, because I like them. most Modern drivers have no idea what a right turn signal iz.
When I built my roadster I shaved the original cowl lights and left the signals off the front. You only really need rear turn signals anyway.
2 more cents, or nonsense, I like cowl lights.... lots a folks want em gone, but 2 me they ahve character.....look at lots of pics....then decide.
Yep, some people like 'em. Believe it or not, when I bought a complete '34 sedan delivery in 1968, I was more excited that it still had it's cowl lights than I was about the fact that it was a sedan delivery!:eek:
Originally Posted by PeteVS "I'm considering '32 cowl lights for my '29 open wheel roadster project" Are you going to mount them in the trunk as courtesy lights?
Mine are mounted inside my 32 headlights used amber bulb to help distinguish them. When not used you can hardly see them.
Ron, we have read your comments on cars your working on. Please post a photo of the 27T project!
Well, I've made a decision. I'm using the '32 cowl lights but not on the cowl. This is just a mock up...
