eystein
Installing the cowl light wiring and the instructions that came with the wiring says that the part where the two wires are enclosed in a loom should go up through the cowl pillar, however in that gase the wire is too short. Should the wires rather just hang straight down behind the cowl panel from the left cowl lamp ? Would it not be fastened in any way ? After exiting from the body between the outer cowl skin and floorboard riser into the engine compertment, is the loom routed over or under the engine mounts?
