cowl/door post ID
Brubaker
Have a chance to acquire the wood for inside the front door posts, but something does not look quite right(pieces vs what I have). Should be a 1930 Murray Town Sedan(?). It's not a Briggs cowl is it? Firewall tag and doors are definitely Murray. Thanks
The lower metal support(w/ 4 holes) that is riveted and bolted through the sill piece hopefully is a good clue. I need to find a '30 Briggs Town Sedan with the kick panels off.
Negative Bruce, I think ( now for sure ) somewere in the past the wood was replaced by steel. I can send you pictures if you want but need a emailadress to send. Thanks Gerard.
