rhphotord
I must be an idiot asking this question but what's the trick you use to install a 30 cowl band. Body is on the frame and just trimming it out but I can't get the lower mounting bolt on the drivers side to align with the mounting hole. It appears clear and should line up from what I see. Stock cowl band came with car and it was on it when I got the car and retaining clips are in place.
Looks like a simple installation but really tight quarters to work. I'm not about to give up but I had to walk away from the car after two hours of frustration!
Help appreciated!
Help appreciated!
