Coupling shaft
Brian T
San Diego
Ca
I am still seeking a coupling shaft that was used on a 28-29 Double A truck, it is the shaft between the transmission and the main drive shaft, where a Hi-Low reduction box was used, but not factory fitted.
My intensions are to install a Mitchell transmission with 15% improved 1st- 2nd gears, and remove the Hi-Lo unit, I am hoping someone may have a coupling laying around that they wish to dispose of,---- in addition a u-joint with 6-10 splines that has the replaceable cross in any condition as long as the knuckles are not worn would be helpful.
Thank for looking.
